Risultati da 1 a 9 di 9
Like Tree1Likes
  • 1 Post By _sabba_
Discussione: Procedura di reset Cruise Control x Tiger Sport 1050 e Tiger Explorer (in inglese)
    If you got problems on Cruise Control system, reading CHECK P1575 into ECU logs, you can try the following steps to see if a reset helps.
    Once again, I will stress that this is the procedure from the Tiger Explorer, and it works on Tiger Sport 1050 too (model 2016 upward). I never had to try it on either bike.
    The Cruise Control switch check is required after certain DTC's or defects have been repaired with relate to the ride by wire system or Cruise Control system, or after the adaptations have been reset. The switch check requires the user to operate the switches in order.
    Ignition ON, Engine OFF
    1) Activate the Front Brake Switch by pulling and releasing the font brake
    2) Activate the Rear Brake Switch by pressing and releasing the rear brake pedal
    3) Activate the Clutch Switch by pulling and releasing the Clutch
    4) Activate the Twist Grip Cruise Control cancel switch by operating and holding the throttle grip in the fully closed position
    5) Press the Cruise Control On/Off switch to ON
    6) Press the Cruise Control +/Accelerate Switch
    7) Press the Cruise Control -/ Decelerate Switch
    If the CC light goes off, the CC is now reset.
    If that doesn't work, I would recommend returning to the dealer. I know it is an annoyance, but likely a very simple fix.
    Ultima modifica di _sabba_; 02/04/2017 alle 00:36
    Matthew_BS likes this.
    TCP Rider L'avatar di baltoheidi
    genova
    tiger sport black
    Traduci che io sono ignorante..grazie
    Inviato dal mio SM-G531F utilizzando Tapatalk
    Accendere il quadro, ma non avviare il motore
    1) Attivare lo switch (interruttore) del freno anteriore, tirando e rilasciando la leva DX sul manubrio
    2) Attivare lo switch del freno posteriore, premendo e rilasciando il pedale
    3) Attivare lo switch della frizione, tirando e rilasciando la leva SX sul manubrio
    4) Attivare lo switch dell'acceleratore, ruotando la manopola del gas in avanti, oltre alla posizione "zero".
    5) Premere il tasto di accensione del Cruise Control (può essere dedicato oppure il tasto "-/Decelerate")
    6) Premere il tasto Cruise Control +/Accelerate
    7) Premere il tasto Cruise Control -/Decelerate
    Se si spegne la spia nel cruscotto, il Cruise Control si è ripristinato.
    N.B.: se per qualche motivo la procedura non dovesse funzionare, dovete rivolgervi alla Assistenza Ufficiale Triumph
    Ultima modifica di _sabba_; 01/06/2017 alle 05:44
    TCP Rider L'avatar di Bob Manubrio
    Brianza
    Ex Tiger 1050 bianchissima - Graziella Sport 1050 nera opaca
    Ho dovuto fara anch'io oggi, che strano, chissà perché va in palla
    Funziona che per la Tiger 800 XRX/XCX,
    Testato personalmente.
    Nuovo TCP Rider L'avatar di ivo55
    milano
    tiger 800
    grazie , ho avuto lo stesso problema , ritirato la moto dal concessionario ha aggiornato il software , la prima cosa strana che ho notato
    che si accendeva la spia del cruise control alla rotazione della chiave poi alla accensione si spegneva . Ieri provo in autostrada il cruise e non
    funzionava , ora ho eseguito la procedura di reset e la spia non si accende più . Alla prima occasione lo provo ma sono fiducioso
    Terni
    Rispolvero 😅…Tiger XCA 2018 Testato funziona!!! G R A Z I E !!!!👍👍👍
    Funziona anche per la Tiger 900 (testato oggi):
    5) Premere il tasto CruiseControl +/Accelerate
    6) Premere il tasto CruiseControl -/Decelerate
    Se si spegne la spia nel cruscotto, il CruiseControl si è ripristinato.
  1. Kaoko Cruise Control, il cruise control meccanico: che ne pensate?
    Risposte: 43
  2. Vendo Kaoko CRUISE CONTROL per Tiger 800 XC della Touratech
    Di bricofera nel forum Compro e vendo accessori per Tiger 800/800 XC
  3. Vendo Kaoko CRUISE CONTROL per Tiger 800 ( anche xc) CON Paramani
    Di montaperti nel forum Compro e vendo accessori per Tiger 800/800 XC
  4. Brakeaway Control Cruise per SPEED 1050
    Di CHAUS-11 nel forum Speed Triple
  5. Cruise Control per Tiger
    Di gitti nel forum Tiger/Sprint ST
    Risposte: 18
